旧 2024-07-16, 00:36   #1
默认 A Treacherous SVD - Cleve Moler on Mathematics and Computing
A few days ago, a bug report from our office in Cambridge caught my attention. Computing the singular values and singular vectors of a particular matrix would sometimes cause MATLAB to crash.
Contents
Two Computers
I use two different two computers regularly. The machine in my home office is a Lenovo ThinkPad® model T14, loaded with two external monitors, several external disc drives, a sound bar and a dedicated internet connection. My traveling machine is a Lenovo ThinkPad X1 Nano with no external hardware.
The report of a crash in the SVD became even more interesting when I found that it happens on my office computer, but not on the portable. A quick check revealed that the CPUs on the two machines come from different manufacturers. The office computer uses an AMD® Ryzen Pro 5 while the traveling machine uses an Intel® Core i7.
Math Libraries
The crash occurs several software layers deep in CGESVD, the LAPACK driver for single precision complex SVD. Various chip manufacturers provide math libraries that have been optimized for their CPUs. However, by default, MATLAB uses the reportedly faster Intel Math Kernel Library, MKL. It is possible to switch to other math libraries.
We have experts at MathWorks who know far more about the details of these libraries than I do. They will soon sort this all out. In the meantime, here is what I have learned about the offending matrix.
G3366394
We refer to the matrix in the crash report by its case number in our bug tracking system. The matrix is of modest size but is otherwise unusual for several reasons. It is rectangular with fewer rows than columns, it is in single precision, and it is complex.
clear load g3366394 X whos Name Size Bytes Class Attributes X 219x384 672768 single complexThe following code calling SVD with three outputs will crash MATLAB on my T14, but not on my X1.
trysvd = false if trysvd [U,S,V] = svd(X); R = U*S*V' - X; relres = norm(R)/norm(X) end trysvd = logical 0Rank
Computing the singular values without the vectors can be done on either machine. The following code uses double precision and then plots the singular values on a logarithmic scale with a line at single precision roundoff level.
S = svd(X); semilogy(S,'.-') ep = eps('single'); line([0 230],[ep ep]) axis([0 230 1e-15 10]) legend({'singular values','eps(''single'')'})
We see that the matrix is far from full rank. About half of its singular values are negligible. This is confirmed by
xrank = rank(X) xrank = 110Zero rows
The cause of the low rank is easy to find. This surf plot reveals that almost half of the rows are flat zero.
Let's remove the zero rows.
c = sum(abs(X),2)==0; nnzc = nnz(c) X(c>0,:) = []; nnzc = 109
The remaining matrix is full rank and it is safe to compute its singular vectors.
[U,S,V] = svd(X); R = U*S*V' - X; resnorm = norm(R) resnorm = 2.8191e-06Fuzz
Removing the zero rows was the first work-around that I tried. There are many others. You can replace the zeros with any nonzero "fuzz".
fuzz = 1.e-20; [U,S,V] = svd(X + fuzz*randn(size(X))); resnorm = norm(U*S*V'-X) resnorm = 2.8222e-06Flip
You can reorder the matrix so that the zero rows are not at the beginning.
[U,S,V] = svd(flipud(X)); U = flipud(U); resnorm = norm(U*S*V'-X) resnorm = 2.3809e-06Now what?
How to avoid the crash is not the most important question. What causes the crash with the original matrix? We will find out and get it fixed.
Published with MATLAB® R2024a
所有时间均为北京时间。现在的时间是 03:22。
