旧 2019-12-05, 03:07   #1
默认 A Matrix for the New HPL-AI Benchmark - Cleve Moler on Mathematics and Computing
My colleagues are looking for a matrix to be used in a new benchmark. They've come to the right place.
Contents
Email
A couple of weeks ago I got this email from Jack Dongarra at the University of Tennessee.
For this new HPL-AI benchmark, I'm looking for a matrix that is not symmetric, is easily generated (roughly O(n^2) ops to generate), is dense, doesn’t require pivoting to control growth, and has a smallish condition number ( -1, the largest element is on the diagonal and lu(A(n,mu)) does no pivoting.
format short mu = -1 [L,U] = lu(A(n,mu)) mu = 1 [L,U] = lu(A(n,mu)) mu = -1 L = 1.0000 0 0 0 0 0.2083 1.0000 0 0 0 0.2778 0.1748 1.0000 0 0 0.4167 0.2265 0.1403 1.0000 0 0.8333 0.3099 0.1512 0.0839 1.0000 U = 1.2000 0.1667 0.1429 0.1250 0.1111 0 1.1653 0.1369 0.1168 0.1019 0 0 1.1364 0.1115 0.0942 0 0 0 1.1058 0.0841 0 0 0 0 1.0545 mu = 1 L = 1.0000 0 0 0 0 0.1094 1.0000 0 0 0 0.0972 0.0800 1.0000 0 0 0.0875 0.0729 0.0626 1.0000 0 0.0795 0.0669 0.0580 0.0513 1.0000 U = 1.1429 0.1250 0.1111 0.1000 0.0909 0 1.0974 0.0878 0.0800 0.0734 0 0 1.0731 0.0672 0.0622 0 0 0 1.0581 0.0542 0 0 0 0 1.0481 Condition
Let's see how the 2-condition number, $\sigma_1/\sigma_n$, varies as the parameters vary. Computing the singular values for all the matrices in the following plots takes a little over 10 minutes on my laptop.
sigma_1
load HPLAI.mat s1 sn n mu surf(mu,n,s1) view(25,12) xlabel('mu') ylabel('n') set(gca,'xlim',[-0.9 1.0], ... 'xtick',[-0.9 -0.5 0 0.5 1.0], ... 'ylim',[0 2500]) title('\sigma_1') The colors vary as mu varies from -0.9 up to 1.0. I am staying away from mu = -1.0 where the matrix looses diagonal dominance. The other horizontal axis is the matrix order n. I have limited n to 2500 in these experiments.
The point to be made is that if mu > -0.9, then the largest singular value is bounded, in fact sigma_1 < 2.3.
sigma_n
surf(mu,n,sn) view(25,12) xlabel('mu') ylabel('n') set(gca,'xlim',[-0.9 1.0], ... 'xtick',[-0.9 -0.5 0 0.5 1.0], ... 'ylim',[0 2500]) title('\sigma_n') If mu > -0.9, then the smallest singular value is bounded away from zero, in fact sigma_n > .75.
sigma_1/sigma_n
surf(mu,n,s1./sn) view(25,12) xlabel('mu') ylabel('n') set(gca,'xlim',[-0.9 1.0], ... 'xtick',[-0.9 -0.5 0 0.5 1.0], ... 'ylim',[0 2500]) title('\sigma_1/\sigma_n') If mu > -0.9, then the condition number in the 2-norm is bounded, sigma_1/sigma_n < 2.3/.75 $\approx$ 3.0 .
Overflow
The HPL-AI benchmark would begin by computing the LU decomposition of this matrix using 16-bit half-precision floating point arithmetic, FP16. So, there is a signigant problem if the matrix order n is larger than 65504. This value is realmax, the largest number that can be represented in FP16. Any larger value of n overflows to Inf.
Some kind of scaling is going to have to be done for n > 65504. Right now, I don't see what this might be.
The alternative half-precision format to FP16 is Bfloat16, which has three more bits in the exponent to give realmax = 3.39e38. There should be no overflow problems while generating this matrix with Bfloat16.
Thanks
Thanks to Piotr Luszczek for working with me on this. We have more work to do.
Published with MATLAB® R2019b
