返回   MATLAB爱好者论坛-LabFans.com > 人工智能 > 进化计算
进化计算 A discussion board for Evolutionary Computation.
旧 2009-07-19, 11:09   #1
surlogics
注册日期: 2009-07-19
年龄: 60
surlogics 正向着好的方向发展
默认 [求助]MATLAB中GA工具箱VECTORIZE 是干什么
[求助]MATLAB中GA工具箱VECTORIZE 是干什么的? 我是一个新手,对matlab不怎么熟练,正在学习ga,请教一些问题,谢谢~
MATLAB中GA工具箱第一个DEMO的最后一个方面的讲到的vectorize是干什么?
该程序源代码如下
%% Vectorizing your fitness function
% Consider the previous fitness function again:
% f(x) = a * (x(1)^2 - x(2)) ^2 + (b - x(1))^2;
% By default, the GA solver only passes in one point at a time to the
% fitness function. However, sometimes speed up can be achieved if the
% fitness function is vectorized to take a set of points and return a set
% of function values.
% For example if the solver wants to evaluate a set of five points in one
% call to this fitness function, then it will call the function with a
% matrix of size 5-by-2, i.e. , 5 rows and 2 columns (recall 2 is the number
% of variables).
% Create an M-file called vectorized_fitness.m with the following code:
% function y = vectorized_fitness(x,a,b)
% y = zeros(size(x,1),1); %Pre-allocate y
% for i = 1:size(x,1)
% x1 = x(i,1);
% x2 = x(i,2);
% y(i) = a * (x1^2 - x2) ^2 + (b - x1)^2;
% end
% This vectorized version of the fitness function takes a matrix x with
% an arbitrary number of points, the rows of x, and returns a column
% vector y of length the same as the number of rows of x.
% We need to specify that the fitness function is vectorized using the
% options structure created using GAOPTIMSET. The options structure is
% passed in as the third argument.
FitnessFunction = @(x) vectorized_fitness(x,100,1);
numberOfVariables = 2;
options = gaoptimset('Vectorized','on');
[x,fval] = ga(FitnessFunction,numberOfVariables,options)
是否是进行初始化?(其中x是一个N维向量,一开始的值是初始值)但是GA需要初始化吗?
另外我在《测试智能信息处理》中看到一个对Griewangk函数的极小化
程序1:Griewangk函数
function[eval]=gw(sol)
numv=size(sol,2);
x=sol*(1:numv);
for i=1:numv
multi=multi*cos(x(i)/sqrt(i));
eval=sum(x.^2/4000)-multi+1;
程序2:Griewangk函数适应度代码
function[sol,eval]=gwmin(sol,options)
numv=size(sol,2)-1;
x=sol(1:numv);
eval=gw(x);
eval=-eval;
遗传算法求解:
bounds=ones(6,1)*[-512 512];
[p,endPop,bestSols,trace]=ga(bounds,'gwmin');
plot(trace(:,1),trace(:,3),'b-')
hold on
plot(trace(:,1),trace(:,2),'b-')
xlabel('Generation');
ylabel=('Fitness');
输出解的变化和种群平均值变化并输出最优解
p=0.002
-0.004
-0.003
0.006
-0.0022
0.0002
我的疑问:在程序2:Griewangk函数适应度代码中的options是什么?我没有输入啊?
sol是解的值吗?eval是适应度函数吗?
我在matlab中进行到[p,endPop,bestSols,trace]=ga(bounds,'gwmin');
就没法进行了:提示
??? Error using ==> gads\private\validate>validNumberofVariables
Number of variables (NVARS) must be a positive number.
Error in ==> gads\private\validate at 43
validNumberofVariables(o.GenomeLength);
Error in ==> ga at 153
[GenomeLength,FitnessFcn,options] = validate(GenomeLength,FitnessFcn,options);
请问是什么意思啊?
另外最优解p有那么多,他们都代表解吗?因为他么都趋近于零所以最优解p=0对吗?
但是为什么vectorize就只输出一个解呢?
谢谢!
surlogics 当前离线   回复时引用此帖
所有时间均为北京时间。现在的时间是 07:32。
