旧 2019-12-14, 20:46   #1
帖子 用于Matlab的Bayes Net Toolbox安装错误MATLAB R2010b
尝试为Matlab测试Bayes Net Toolbox时出现错误,我的操作与此处显示的安装相同,但出现错误(我有Matlab R2010b):
>> cd 'C:\MATLAB\R2010b\FullBNT-1.0.4' >> addpath(genpathKPM(pwd)) Warning: Function C:\MATLAB\R2010b\FullBNT-1.0.4\KPMtools\assert.m has the same name as a MATLAB builtin. We suggest you rename the function to avoid a potential name conflict. > In path at 110 In addpath at 87 Warning: Function C:\MATLAB\R2010b\FullBNT-1.0.4\KPMtools\isscalar.m has the same name as a MATLAB builtin. We suggest you rename the function to avoid a potential name conflict. > In path at 110 In addpath at 87 Warning: Function C:\MATLAB\R2010b\FullBNT-1.0.4\KPMtools\isvector.m has the same name as a MATLAB builtin. We suggest you rename the function to avoid a potential name conflict. > In path at 110 In addpath at 87 >> test_BNT ll = 1.0e-010 * -0.0670 0.1697 cycle 1 lik -51.5585 cycle 2 lik -45.0863 cycle 3 lik -42.9953 ??? Undefined function or method 'finite' for input arguments of type 'double'. Error in ==> ffa at 71 elseif ((lik-likbase) fa1 at 27 [L1, Psi1, LL1] = ffa(X,k,max_iter); Error in ==> test_BNT at 8 fa1 >>
如您所说:在BNT / examples / static / Zoubin / ffa.m和BNT / examples / static / Zoubin / mfa.m中,用infinite替换对过时的finite的调用
这是参考
所有时间均为北京时间。现在的时间是 13:45
