帖子 MATLAB矩阵预分配比动态矩阵扩展慢
在循环的每次迭代中,我都在计算一个MATLAB矩阵。这些矩阵都必须连接在一起以创建一个最终矩阵。我知道进入循环之前此最终矩阵的尺寸,因此尽管使用'zeros'函数预先分配矩阵比初始化空数组然后在循环的每次迭代中简单地添加子数组要快。奇怪的是,当我进行预分配时,我的程序运行得慢得多。这是代码(只有第一行和最后一行不同):
这很慢:
w_cuda = zeros(w_rows, w_cols, f_cols); for j=0:num_groups-1 % gets # of rows & cols in W. The last group is a special % case because it may have fewer than max_row_size rows if (j == num_groups-1 && mod(w_rows, max_row_size) ~= 0) num_rows_sub = w_rows - (max_row_size * j); else num_rows_sub = max_row_size; end; % calculate correct W and f matrices start_index = (max_row_size * j) + 1; end_index = start_index + num_rows_sub - 1; w_sub = W(start_index:end_index,:); f_sub = filterBank(start_index:end_index,:); % Obtain sub-matrix w_cuda_sub = nopack_cu(w_sub,f_sub); % Incorporate sub-matrix into final matrix w_cuda(start_index:end_index,:,:) = w_cuda_sub; end 这很快:
w_cuda = []; for j=0:num_groups-1 % gets # of rows & cols in W. The last group is a special % case because it may have fewer than max_row_size rows if (j == num_groups-1 && mod(w_rows, max_row_size) ~= 0) num_rows_sub = w_rows - (max_row_size * j); else num_rows_sub = max_row_size; end; % calculate correct W and f matrices start_index = (max_row_size * j) + 1; end_index = start_index + num_rows_sub - 1; w_sub = W(start_index:end_index,:); f_sub = filterBank(start_index:end_index,:); % Obtain sub-matrix w_cuda_sub = nopack_cu(w_sub,f_sub); % Incorporate sub-matrix into final matrix w_cuda = [w_cuda; w_cuda_sub]; end 至于其他可能有用的信息-我的矩阵是3D,其中的数字很复杂。与往常一样,任何见识都值得赞赏。
我一直认为任何数组大小的预分配都更快,并且从未进行过实际测试。因此,我做了一个简单的测试,通过追加和预分配方法使用1000次迭代来计时从1x1x3到20x20x3的各种数组大小的总体。这是代码:
arraySize = 1:20; numIteration = 1000; timeAppend = zeros(length(arraySize), 1); timePreAllocate = zeros(length(arraySize), 1); for ii = 1:length(arraySize); w = []; tic; for jj = 1:numIteration w = [w; rand(arraySize(ii), arraySize(ii), 3)]; end timeAppend(ii) = toc; end; for ii = 1:length(arraySize); w = zeros(arraySize(ii) * numIteration, arraySize(ii), 3); tic; for jj = 1:numIteration indexStart = (jj - 1) * arraySize(ii) + 1; indexStop = indexStart + arraySize(ii) - 1; w(indexStart:indexStop,:,:) = rand(arraySize(ii), arraySize(ii), 3); end timePreAllocate(ii) = toc; end; figure; axes; plot(timeAppend); hold on; plot(timePreAllocate, 'r'); legend('Append', 'Preallocate'); 这是(预期的)结果:
