帖子 如何在MATLAB中将许多RGB图像连接成一张图像?
我有一百个大小相等的RGB图像,编号从1到100。我想从中创建一个图像。例如,如果我给出row = 10和column = 10,那么输出应为前10张图像将形成第一行,依此类推。
一种方法是创建一个包含图像的10×10单元阵列,然后使用CELL2MAT将它们分类为大图像。
nRows = 10; nCols = 10; imgCell = cell(nRows,nCols); for iImage = 1:nRows*nCols %# construct image name - fix this like so it conforms to your naming scheme %# also, add the path if necessary imageName = sprintf('image%i.jpg',iImage); %# add the image to imgCell %# images will filled first into all rows of column one %# then into all rows of column 2, etc imgCell{iImage} = imread(imageName); end %# if you want the images to be arranged along rows instead of %# columns, you can transpose imgCell here %# imgCell = imgCell'; %# catenate into big image bigImage = cell2mat(imgCell); %# show the result imshow(bigImage)
所有时间均为北京时间。现在的时间是 14:14。
