帖子 使用直接取自Hartley&Zisserman的直接线性变换进行三角剖分
下面是Matlab函数,该函数实现了“多视图几何”中描述的三角剖分方法。它需要一个立方体的8个角点(OriginalPoints),并将它们投影到两个屏幕上。屏幕点然后位于CameraPoints和ProjectorPoints中。目的是使用直接线性变换从这两个视图重建原始点。不幸的是结果是胡言乱语。
这里还有一个关于SO的主题 ,从中可以对A的行进行归一化,但这并不能改善结果。
三个一般性问题:
  • 在对SVD之前的数据进行归一化时(原点=重心,平均距离= sqrt(2)),我是否要计算(x,y)或(x,y,w)的平均距离?不均匀还是均匀?
  • 在所有操作之后,如有可能,我将齐次坐标w缩放回1.0,这是正确的吗?
  • 由于摄像机矩阵是完全已知的(不仅限于投影变换),因此所得的点与原始点的区别应该不超过欧几里得变换,对吧?
% Demos the triangulation method using the direct linear transform % algorithm function testTriangulation() close all; camWidth = 800; camHeight = 600; projectorWidth = 5080; projectorHeight = 760; % camera matrices CameraMatrix = [ -1.81066 0.00000 0.00000 0.00000; 0.00000 2.41421 0.00000 0.00000; 0.00000 0.00000 1.00000 1.50000 ]; ProjectorMatrix = [ -0.36118 0.00000 0.00000 0.00000 0.00000 2.00875 1.33916 0.00000 0.00000 -0.55470 0.83205 1.80278 ]; % generating original points and displaying them OriginalPoints = [ -0.2 -0.2 -0.2 -0.2 0.2 0.2 0.2 0.2; -0.2 -0.2 0.2 0.2 -0.2 -0.2 0.2 0.2; -0.2 0.2 -0.2 0.2 -0.2 0.2 -0.2 0.2; 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 ]; scatter3(OriginalPoints(1, :), OriginalPoints(2, :), OriginalPoints(3,:)); title('Original Points'); % projecting and normalizing camera points CameraPoints = CameraMatrix * OriginalPoints; for i = 1:3 CameraPoints(i, :) = CameraPoints(i, :) ./ CameraPoints(3,:); end % figure(); % scatter(CameraPoints(1,:), CameraPoints(2,:)); % title('Projected Camera Points'); % transforming camera points to screen coordinates camXOffset = camWidth / 2; camYOffset = camHeight / 2; CameraPoints(1,:) = CameraPoints(1,:) * camXOffset + camXOffset; CameraPoints(2,:) = CameraPoints(2,:) * camYOffset + camYOffset; figure(); scatter(CameraPoints(1,:), CameraPoints(2,:)); title('Projected Camera Points in Screen Coordinates'); % projecting and normalizing projector points ProjectorPoints = ProjectorMatrix * OriginalPoints; for i = 1:3 ProjectorPoints(i, :) = ProjectorPoints(i, :) ./ ProjectorPoints(3,:); end % figure(); % scatter(ProjectorPoints(1,:), ProjectorPoints(2,:)); % title('Projected Projector Points'); % transforming projector points to screen coordinates projectorXOffset = projectorWidth / 2; projectorYOffset = projectorHeight / 2; ProjectorPoints(1,:) = ProjectorPoints(1,:) * projectorXOffset + projectorXOffset; ProjectorPoints(2,:) = ProjectorPoints(2,:) * projectorYOffset + projectorYOffset; figure(); scatter(ProjectorPoints(1,:), ProjectorPoints(2,:)); title('Projected Projector Points in Screen Coordinates'); % normalizing camera points (ie origin is % the centroid and average distance is sqrt(2)). camCenter = mean(CameraPoints, 2); CameraPoints(1,:) = CameraPoints(1,:) - camCenter(1); CameraPoints(2,:) = CameraPoints(2,:) - camCenter(2); avgDistance = 0.0; for i = 1:length(CameraPoints(1,:)) avgDistance = avgDistance + norm(CameraPoints(:, i)); end avgDistance = avgDistance / length(CameraPoints(1, :)); scaleFactor = sqrt(2) / avgDistance; CameraPoints(1:2, :) = CameraPoints(1:2, :) * scaleFactor; % normalizing projector points (ie origin is % the centroid and average distance is sqrt(2)). projectorCenter = mean(ProjectorPoints, 2); ProjectorPoints(1,:) = ProjectorPoints(1,:) - projectorCenter(1); ProjectorPoints(2,:) = ProjectorPoints(2,:) - projectorCenter(2); avgDistance = 0.0; for i = 1:length(ProjectorPoints(1,:)) avgDistance = avgDistance + norm(ProjectorPoints(:, i)); end avgDistance = avgDistance / length(ProjectorPoints(1, :)); scaleFactor = sqrt(2) / avgDistance; ProjectorPoints(1:2, :) = ProjectorPoints(1:2, :) * scaleFactor; % triangulating points TriangulatedPoints = zeros(size(OriginalPoints)); for i = 1:length(OriginalPoints(1, :)) A = [ CameraPoints(1, i) * CameraMatrix(3, :) - CameraMatrix(1, :); CameraPoints(2, i) * CameraMatrix(3, :) - CameraMatrix(2, :); ProjectorPoints(1, i) * ProjectorMatrix(3,:) - ProjectorMatrix(1,:); ProjectorPoints(2, i) * ProjectorMatrix(3,:) - ProjectorMatrix(2,:) ]; % normalizing rows of A, as suggested in a topic on StackOverflow A(1,:) = A(1,:)/norm(A(1,:)); A(2,:) = A(2,:)/norm(A(2,:)); A(3,:) = A(3,:)/norm(A(3,:)); A(4,:) = A(4,:)/norm(A(4,:)); [USV] = svd(A); TriangulatedPoints(:, i) = V(:, end); end for i = 1:4 TriangulatedPoints(i, :) = TriangulatedPoints(i, :) ./ TriangulatedPoints(4, :); end figure() scatter3(TriangulatedPoints(1, :), TriangulatedPoints(2, :), TriangulatedPoints(3, :)); title('Triangulated Points');
上面的代码缺少的是,相机矩阵也需要通过规范化变换来变换。下面是一个有效的示例。还请注意规范化转换的结构差异。在问题的示例中,比例因子位于最后一个元素中。在其下面乘以所有元素,以使最后一个元素为1。
function testTriangulationDavid() close all clear all P = [ -1.81066 0.00000 0.00000 0.00000; 0.00000 2.41421 0.00000 0.00000; 0.00000 0.00000 1.00000 1.50000 ]; Q = [ -0.36118 0.00000 0.00000 0.00000 0.00000 2.00875 1.33916 0.00000 0.00000 -0.55470 0.83205 1.80278 ]; % homogenous 3D coordinates Pts = [ -0.2 -0.2 -0.2 -0.2 0.2 0.2 0.2 0.2; -0.2 -0.2 0.2 0.2 -0.2 -0.2 0.2 0.2; -0.2 0.2 -0.2 0.2 -0.2 0.2 -0.2 0.2; 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 ]; numPts = length(Pts(1,:)); % project points PPtsHom = P*Pts; QPtsHom = Q*Pts; % normalize for homogenous scaling for i = 1:3 PPtsHom(i, :) = PPtsHom(i, :) ./ PPtsHom(3, :); QPtsHom(i, :) = QPtsHom(i, :) ./ QPtsHom(3, :); end % 2D cartesian coordinates PPtsCart = PPtsHom(1:2,:); QPtsCart = QPtsHom(1:2,:); % compute normalizing transform % calc centroid centroidPPtsCart = mean(PPtsCart,2); centroidQPtsCart = mean(QPtsCart,2); % calc mean distance to centroid normsPPtsCart = zeros(1, numPts); normsQPtsCart = zeros(1, numPts); for i = 1:numPts normsPPtsCart(1,i) = norm(PPtsCart(:,i) - centroidPPtsCart); normsQPtsCart(1,i) = norm(QPtsCart(:,i) - centroidQPtsCart); end mdcPPtsCart = mean(normsPPtsCart); mdcQPtsCart = mean(normsQPtsCart); % setup transformation scaleP = sqrt(2)/mdcPPtsCart; scaleQ = sqrt(2)/mdcQPtsCart; tP = [ scaleP 0 -scaleP*centroidPPtsCart(1); 0 scaleP -scaleP*centroidPPtsCart(2); 0 0 1]; tQ = [ scaleQ 0 -scaleQ*centroidQPtsCart(1); 0 scaleQ -scaleQ*centroidQPtsCart(2); 0 0 1]; % transform points PPtsHom = tP * PPtsHom; QPtsHom = tQ * QPtsHom; % normalize for homogenous scaling for i = 1:3 PPtsHom(i, :) = PPtsHom(i, :) ./ PPtsHom(3, :); QPtsHom(i, :) = QPtsHom(i, :) ./ QPtsHom(3, :); end % 2D cartesian coordinates PPtsCart = PPtsHom(1:2,:); QPtsCart = QPtsHom(1:2,:); % transform cameras P = tP * P; Q = tQ * Q; % triangulating points TriangulatedPoints = zeros(4,numPts); for i = 1:numPts A = [ PPtsCart(1, i) * P(3, :) - P(1, :); PPtsCart(2, i) * P(3, :) - P(2, :); QPtsCart(1, i) * Q(3,:) - Q(1,:); QPtsCart(2, i) * Q(3,:) - Q(2,:) ] return; [USV] = svd(A); TriangulatedPoints(:, i) = V(:, end); end for i = 1:4 TriangulatedPoints(i, :) = TriangulatedPoints(i, :) ./ TriangulatedPoints(4, :); end figure() scatter3(TriangulatedPoints(1, :), TriangulatedPoints(2, :), TriangulatedPoints(3, :)); title('Triangulated Points'); axis equal;
所有时间均为北京时间。现在的时间是 18:14
