帖子 反向传播实施问题
我应该怎么做。我有一个黑白图像(100x100px):
我应该用这个图像训练一个反向传播神经网络。输入是图像的x,y坐标(从0到99),输出是1(白色)或0(黑色)。
网络学习完后,我希望它根据权重重现图像并获得与原始图像最接近的图像。
这是我的backprop实现:
import os import math import Image import random from random import sample #------------------------------ class definitions class Weight: def __init__(self, fromNeuron, toNeuron): self.value = random.uniform(-0.5, 0.5) self.fromNeuron = fromNeuron self.toNeuron = toNeuron fromNeuron.outputWeights.append(self) toNeuron.inputWeights.append(self) self.delta = 0.0 # delta value, this will accumulate and after each training cycle used to adjust the weight value def calculateDelta(self, network): self.delta += self.fromNeuron.value * self.toNeuron.error class Neuron: def __init__(self): self.value = 0.0 # the output self.idealValue = 0.0 # the ideal output self.error = 0.0 # error between output and ideal output self.inputWeights = [] self.outputWeights = [] def activate(self, network): x = 0.0; for weight in self.inputWeights: x += weight.value * weight.fromNeuron.value # sigmoid function if x < -320: self.value = 0 elif x > 320: self.value = 1 else: self.value = 1 / (1 + math.exp(-x)) class Layer: def __init__(self, neurons): self.neurons = neurons def activate(self, network): for neuron in self.neurons: neuron.activate(network) class Network: def __init__(self, layers, learningRate): self.layers = layers self.learningRate = learningRate # the rate at which the network learns self.weights = [] for hiddenNeuron in self.layers[1].neurons: for inputNeuron in self.layers[0].neurons: self.weights.append(Weight(inputNeuron, hiddenNeuron)) for outputNeuron in self.layers[2].neurons: self.weights.append(Weight(hiddenNeuron, outputNeuron)) def setInputs(self, inputs): self.layers[0].neurons[0].value = float(inputs[0]) self.layers[0].neurons[1].value = float(inputs[1]) def setExpectedOutputs(self, expectedOutputs): self.layers[2].neurons[0].idealValue = expectedOutputs[0] def calculateOutputs(self, expectedOutputs): self.setExpectedOutputs(expectedOutputs) self.layers[1].activate(self) # activation function for hidden layer self.layers[2].activate(self) # activation function for output layer def calculateOutputErrors(self): for neuron in self.layers[2].neurons: neuron.error = (neuron.idealValue - neuron.value) * neuron.value * (1 - neuron.value) def calculateHiddenErrors(self): for neuron in self.layers[1].neurons: error = 0.0 for weight in neuron.outputWeights: error += weight.toNeuron.error * weight.value neuron.error = error * neuron.value * (1 - neuron.value) def calculateDeltas(self): for weight in self.weights: weight.calculateDelta(self) def train(self, inputs, expectedOutputs): self.setInputs(inputs) self.calculateOutputs(expectedOutputs) self.calculateOutputErrors() self.calculateHiddenErrors() self.calculateDeltas() def learn(self): for weight in self.weights: weight.value += self.learningRate * weight.delta def calculateSingleOutput(self, inputs): self.setInputs(inputs) self.layers[1].activate(self) self.layers[2].activate(self) #return round(self.layers[2].neurons[0].value, 0) return self.layers[2].neurons[0].value #------------------------------ initialize objects etc inputLayer = Layer([Neuron() for n in range(2)]) hiddenLayer = Layer([Neuron() for n in range(10)]) outputLayer = Layer([Neuron() for n in range(1)]) learningRate = 0.4 network = Network([inputLayer, hiddenLayer, outputLayer], learningRate) # let's get the training set os.chdir("D:/stuff") image = Image.open("backprop-input.gif") pixels = image.load() bbox = image.getbbox() width = 5#bbox[2] # image width height = 5#bbox[3] # image height trainingInputs = [] trainingOutputs = [] b = w = 0 for x in range(0, width): for y in range(0, height): if (0, 0, 0, 255) == pixels[x, y]: color = 0 b += 1 elif (255, 255, 255, 255) == pixels[x, y]: color = 1 w += 1 trainingInputs.append([float(x), float(y)]) trainingOutputs.append([float(color)]) print "\nOriginal image ... Black:"+str(b)+" White:"+str(w)+"\n" #------------------------------ let's train for i in range(500): for j in range(len(trainingOutputs)): network.train(trainingInputs[j], trainingOutputs[j]) network.learn() for w in network.weights: w.delta = 0.0 #------------------------------ let's check b = w = 0 for x in range(0, width): for y in range(0, height): out = network.calculateSingleOutput([float(x), float(y)]) if 0.0 == round(out): color = (0, 0, 0, 255) b += 1 elif 1.0 == round(out): color = (255, 255, 255, 255) w += 1 pixels[x, y] = color #print out print "\nAfter learning the network thinks ... Black:"+str(b)+" White:"+str(w)+"\n" 显然,我的实现存在一些问题。上面的代码返回:
原始图像...黑色:21白色:4
学习后网络思考...黑色:25白色:0
如果我尝试使用更大的训练集,它也会做同样的事情(出于测试目的,我仅测试上图中的25个像素)。它返回学习后所有像素应为黑色。
现在,如果我使用这样的手动训练集代替:
trainingInputs = [ [0.0,0.0], [1.0,0.0], [2.0,0.0], [0.0,1.0], [1.0,1.0], [2.0,1.0], [0.0,2.0], [1.0,2.0], [2.0,2.0] ] trainingOutputs = [ [0.0], [1.0], [1.0], [0.0], [1.0], [0.0], [0.0], [0.0], [1.0] ] #------------------------------ let's train for i in range(500): for j in range(len(trainingOutputs)): network.train(trainingInputs[j], trainingOutputs[j]) network.learn() for w in network.weights: w.delta = 0.0 #------------------------------ let's check for inputs in trainingInputs: print network.calculateSingleOutput(inputs) 输出例如:
0.0330125791296 # this should be 0, OK 0.953539182136 # this should be 1, OK 0.971854575477 # this should be 1, OK 0.00046146137467 # this should be 0, OK 0.896699762781 # this should be 1, OK 0.112909223162 # this should be 0, OK 0.00034058462280 # this should be 0, OK 0.0929886299643 # this should be 0, OK 0.940489647869 # this should be 1, OK 换句话说,网络猜测所有像素正确(黑色和白色)。如果我使用图像中的实际像素而不是像上面这样的硬编码训练集,为什么为什么所有像素都应该是黑色的?
我尝试更改隐藏层(最多100个神经元)中神经元的数量,但没有成功。
这是一项作业。
这也是我先前关于反向传播的问题的延续。
已经有一段时间了,但是我确实获得了这方面的学位,所以我希望其中的一些能够坚持下去。
据我所知,您对输入层的中层神经元的负担太深了。也就是说,您的输入集包含10,000个离散输入值(100像素x 100像素);您正在尝试将这10,000个值编码为10个神经元。这种级别的编码很困难(我怀疑这是可能的,但肯定很困难)。至少,您需要大量的培训(超过500次跑步)才能使其合理地复制。即使中间层有100个神经元,您也会看到相对密集的压缩级别(100个像素到1个神经元)。
关于如何解决这些问题;好吧,这很棘手。您可以显着增加中枢神经元的数量,并且会获得合理的效果,但是当然这需要花费很长时间进行训练。但是,我认为可能会有不同的解决方案。如果可能,您可以考虑使用极坐标代替直角坐标作为输入;输入模式的快速眼动表明高度的对称性,实际上,您会看到一种线性模式,该模式具有沿角坐标重复的可预测变形,这似乎可以在少量的中层神经元中很好地编码。
这些东西很棘手。寻求模式编码的通用解决方案(就像您的原始解决方案一样)非常复杂,并且通常(即使有大量的中间层神经元)也需要大量的训练通行证;另一方面,一些预先启发式任务分解和一些问题重新定义(即,从笛卡尔坐标转换为极坐标)可以为定义明确的问题集提供良好的解决方案。当然,其中永远是摩擦。通用解决方案很难获得,但稍微多一些指定的解决方案确实可以很好。
无论如何,有趣的东西!
