旧 2008-04-18, 22:30   #1
TechnicalArticles
游客
帖子: n/a
默认 Using Functional Electrical Stimulation to Restore Movement to Individuals with Neuro
By Stephen Trier, Tina Vrabec, and Jeff Weisgarber
Cleveland FES Center and
Case Western Reserve University Department of Biomedical Engineering
For individuals with neurological impairments, functional electrical stimulation (FES) can help make real what was once only imagined: the restoration of movement to paralyzed arms and legs. Depending on the location and severity of the disability, FES can significantly improve quality of life by enabling the individual to regain capabilities such as walking, grasping objects, or maintaining bladder control.
FES devices send electrical impulses to electrodes—implanted in the body, worn on the skin, or operating through the skin—to produce and control movement. While a great deal is known about how electrical stimulation affects paralyzed nerves and muscles, until now a challenge has been the need to customize each device for the individual patient’s abilities and disabilities.
In this article, researchers at Case Western University describe how they developed the Universal External Control Unit (UECU), a flexible, configurable system technology platform for FES applications. With UECU, engineers in the clinic can change an FES controller and immediately see the results, enabling them to make improvements up to ten times faster than they could do before.
FES devices help restore movement to paralyzed muscles by controlling the electrical signals used to stimulate nerves and muscle tissue. The devices translate input from transducers or other devices that the patient can control into complex stimulus patterns that produce the desired motion in paralyzed or uncontrollable muscles.
Researchers at the Cleveland FES center have developed FES devices for a diverse range of applications, including:
  • Restoring hand and arm function to persons with quadriplegia
  • Enabling paraplegic patients to stand and walk
  • Improving motor control and gait after stroke
  • Restoring bladder and bowel function
  • Improving tissue health by preventing pressure sores
Each application uses a combination of one or more implanted stimulators, percutaneous electrodes, or surface electrodes to produce movement.
In developing the UECU, we had three primary goals. First, we wanted the UECU hardware and software to be modular and flexible enough to be used for a wide variety of FES applications. Second, the design environment had to enable researchers and rehabilitation engineers—not expert programmers—to develop rapid prototypes and quickly translate basic research into actual clinical systems. Third, the UECU had to work effectively in several disparate settings: in the laboratory, where basic research is the focus and rapid turnaround is important; in the clinic, where applications are customized for each patient; and in the patient’s home, where the key requirements are portability, robustness, and ease of use.
Developing the UECU Blockset
We used Simulink® from the very start of the project. As a proof of concept, we connected a Freescale microcontroller evaluation board to a prototype implant control module and wrote S-functions to control this hardware. We were able to create a simple FES controller in Simulink and generate code from the model with Real-Time Workshop®. The proof-of-concept system worked, and demonstrated that we could get real-time control of stimulation pulses from a Simulink model.
From there, we developed and refined the software. While the hardware engineers designed the electronics, the software developers divided the UECU’s capabilities into functional building blocks that researchers can use to assemble FES applications. We included these blocks in a custom Simulink blockset. The UECU Blockset provides more than 75 blocks, including individual blocks for accessing input from analog devices, joint angle transducers, myoelectric signals, and simple buttons, as well as blocks for generating simulation pulses and producing sounds, lights, and other feedback from the control unit.
Along with the blockset, we developed a custom Real-Time Workshop target for the UECU. An adaptation of the generic real-time target provided in the package, our target configures the C compiler and other tools to correctly compile for the UECU. With the target, a clinical engineer can use a single Build command to turn a Simulink model into a compiled program downloaded to a UECU and ready to run.
Accelerating Development of FES Applications
Because applications are assembled from Simulink blocks, our researchers can build FES control software up to ten times faster than before.
FES applications used to be developed in C by dedicated programmers. The development group supported multiple clinical groups, each of which specialized in a different disability. When a clinical group needed a new feature or capability, they sent a request to the programmers, waited for a new version of the software, and then tested it in the clinic. While coding in C was very flexible, the overall process was slow, limiting how quickly we could move from idea to reality. Worse, because the programmers might not understand what was needed, it often took several iterations before the clinical group had a change that met their needs.
The Simulink based UECU has enabled our central development group to focus on building and maintaining a single system. The system’s flexibility and ease of use make it possible for each clinical group to rapidly develop and refine their own FES applications (Figure 1).
Figure 1. Application developed by a clinician to provide arm and hand control using an implanted stimulator. Click on image to see enlarged view.
Building a Rapid Prototype
Once a design is completed, researchers use Real-Time Workshop to generate code from their Simulink model. Often researchers test new ideas by building a rapid prototype with xPC Target™. This approach enables them to use simpler floating-point designs to validate ideas on PC-compatible hardware before committing the design to portable, fixed-point target hardware.
Once a basic controller design has been developed, we must still fine-tune the stimulus parameters that it uses to control the patient’s muscles (Figure 2).
Figure 2. A clinician adjusts the stimulus parameters on a paralyzed patient’s FES device.
We designed the UECU with non-volatile memory in which we store a table of stimulus data. In an arm control application, for example, this table is used to translate a scalar control signal into a vector of 8 to 16 numbers that control the pulses sent to nerves and muscles in the patient’s arm. To optimize the stimulus patterns, we set the signal levels at an initial starting point, see how they perform with the patient’s arm, then adjust the levels in an iterative process (Figure 3). Because muscles grow stronger or weaker over time, we have to repeat this process every so often to keep the FES system performing at its best.
Figure 3. The pattern editor enables clinicians to rapidly create new stimulus patterns and fine-tune FES applications. Click on image to see enlarged view.
From Idea to Implementation in a Single Day
A case involving an early version of a myoelectric control highlights the speed with which clinicians can now implement new ideas. A patient had come in from out of town, and would be the first to use this form of control, in which the electrical activity of a fully functional muscle is used to control muscles that are paralyzed. At that time, the controller did not work as well as it does today, and we were unable to get the system running to our satisfaction.
We all wanted to send the patient home with a system that he could use to control his hands. On the last day of the patient’s visit, one of the rehabilitation engineers had an idea: Why not use the sip-and-puff control, a straw that the patient blows or suck to control his wheelchair? In one day, the engineer developed an algorithm that incorporated this unique feature into the control software. Using Simulink and the UECU Blockset, he had the algorithm tested and working by the time the patient left the clinic. Previously, this kind of effort would have taken a week or more.
The UECU in Research
At present, the UECU is used primarily for restoring limb movement, but research groups also use it to develop other applications. In one initiative, a Biomedical Engineering graduate student used Simulink and the UECU to develop an experimental application for bladder control. Because only a limited amount of hardware was available for testing, he modeled, simulated, and tested the control logic entirely in Simulink. When hardware was available, we needed less than an hour to get his model working on the actual UECU.
Another group of graduate students used the UECU to develop a slip detector that can sense when an object is slipping from someone’s hand. Using a piezoelectric sensor and signal processing developed in Simulink, a slip detector like this may eventually provide valuable feedback for those who have no sense of touch in their hands.
Continuing to Improve Quality of Life
With UECU, our clinical teams can build increasingly sophisticated applications that let patients have more control than before. We can, for example, control two implants with a single external controller, providing the patient with greater function and better portability. Using our rapid prototyping environment, clinical engineers have built neuro-prosthetic applications for many different types of injury. More than 30 UECUs are currently in use by patients.
We continue to develop new modules for the UECU. We expect to deploy a radio module with multiple RF transceivers that will interface to a wireless transducer system developed at the Cleveland FES Center, as well as a surface electromyogram (EMG) module for measuring muscular activity from the surface of the skin.
We are also planning a multi-channel transducer module that will collect data from a wide variety of transducers, and a DSP module that will significantly increase the computing power of the UECU, allowing the system to handle more computationally intense applications. These advances will enable patients to more naturally control their arms and legs—by directing multiple joints at once, for example—and as a result, to resume a more active life.
In the next five to ten years, we aim to replace the UECU and its companion implants with a new, fully internal system. Having an FES system completely inside the body will improve independence in places UECU cannot go today, such as in the shower or the pool, and will provide a more natural experience in any setting. The lab prototypes of the new system are already running programs created with Simulink and Real-Time Workshop.
  回复时引用此帖
