帖子 根据法线向量和Matlab或matplotlib中的点绘制平面
如何从法向矢量和一个点在matlab或matplotlib中绘制平面?
对于Matlab:
point = [1,2,3]; normal = [1,1,2]; %# a plane is a*x+b*y+c*z+d=0 %# [a,b,c] is the normal. Thus, we have to calculate %# d and we're set d = -point*normal'; %'# dot product for less typing %# create x,y [xx,yy]=ndgrid(1:10,1:10); %# calculate corresponding z z = (-normal(1)*xx - normal(2)*yy - d)/normal(3); %# plot the surface figure surf(xx,yy,z)
注意:仅当normal(3)不为0时,此解决方案才有效。如果平面平行于z轴,则可以旋转尺寸以保持相同的方法:
z = (-normal(3)*xx - normal(1)*yy - d)/normal(2); %% assuming normal(3)==0 and normal(2)~=0 %% plot the surface figure surf(xx,yy,z) %% label the axis to avoid confusion xlabel('z') ylabel('x') zlabel('y')
所有时间均为北京时间。现在的时间是 17:09。
