帖子 MATLAB中10倍SVM分类的示例
我需要一个说明性的示例,展示如何对两类数据集进行10倍SVM分类。 MATLAB文档中只有一个示例,但并非十折。有人能帮我吗?
这是一个完整的示例,使用了生物信息学工具箱中的以下功能: SVMTRAIN , SVMCLASSIFY , CLASSPERF和CROSSVALIND 。
load fisheriris %# load iris dataset groups = ismember(species,'setosa'); %# create a two-class problem %# number of cross-validation folds: %# If you have 50 samples, divide them into 10 groups of 5 samples each, %# then train with 9 groups (45 samples) and test with 1 group (5 samples). %# This is repeated ten times, with each group used exactly once as a test set. %# Finally the 10 results from the folds are averaged to produce a single %# performance estimation. k=10; cvFolds = crossvalind('Kfold', groups, k); %# get indices of 10-fold CV cp = classperf(groups); %# init performance tracker for i = 1:k %# for each fold testIdx = (cvFolds == i); %# get indices of test instances trainIdx = ~testIdx; %# get indices training instances %# train an SVM model over training instances svmModel = svmtrain(meas(trainIdx,:), groups(trainIdx), ... 'Autoscale',true, 'Showplot',false, 'Method','QP', ... 'BoxConstraint',2e-1, 'Kernel_Function','rbf', 'RBF_Sigma',1); %# test using test instances pred = svmclassify(svmModel, meas(testIdx,:), 'Showplot',false); %# evaluate and update performance object cp = classperf(cp, pred, testIdx); end %# get accuracy cp.CorrectRate %# get confusion matrix %# columns:actual, rows:predicted, last-row: unclassified instances cp.CountingMatrix 输出:
ans = 0.99333 ans = 100 1 0 49 0 0 我们获得了99.33%准确度,其中只有一个被错误分类为“非setosa”的“ setosa”实例
更新 :SVM功能已移至R2013a中的“统计”工具箱
