帖子 为什么每次都要重新初始化此类?
我有4个文件,并且代码“正常”。
我尝试清理所有内容,将代码放入函数中,等等……一切看起来都很好……而且行不通。有人可以解释一下MatLab为何如此古怪...还是我只是愚蠢?
通常我会输入
terminator = simulation(100,20,0,0,0,1); terminator.animate(); 并应绘制出带有终结者在森林中四处走动的树木的地图。一切都旋转到他的角度。
当我将其分解为功能时,一切都会停止工作。
我真的只更改了几行代码,如注释所示。
起作用的代码:
classdef simulation properties landmarks robot end methods function obj = simulation(mapSize, trees, x,y,heading,velocity) obj.landmarks = landmarks(mapSize, trees); obj.robot = robot(x,y,heading,velocity); end function animate(obj) %Setup Plots fig=figure; xlabel('meters'), ylabel('meters') set(fig, 'name', 'Phil''s AWESOME 80''s Robot Simulator') xymax = obj.landmarks.mapSize*3; xymin = -(obj.landmarks.mapSize*3); l=scatter([0],[0],'bo'); axis([xymin xymax xymin xymax]); obj.landmarks.apparentPositions %Simulation Loop THIS WAS ORGANIZED for n = 1:720, %Calculate and Set Heading/Location obj.robot.headingChange = navigate(n); %Update Position obj.robot.heading = obj.robot.heading + obj.robot.headingChange; obj.landmarks.heading = obj.robot.heading; y = cosd(obj.robot.heading); x = sind(obj.robot.heading); obj.robot.x = obj.robot.x + (x*obj.robot.velocity); obj.robot.y = obj.robot.y + (y*obj.robot.velocity); obj.landmarks.x = obj.robot.x; obj.landmarks.y = obj.robot.y; %Animate set(l,'XData',obj.landmarks.apparentPositions(:,1),'YData',obj.landmarks.apparentPositions(:,2)); rectangle('Position',[-2,-2,4,4]); drawnow end end end end ----------- classdef landmarks properties fixedPositions %# positions in a fixed coordinate system. [ x, y ] mapSize = 10; %Map Size. Value is side of square x=0; y=0; heading=0; headingChange=0; end properties (Dependent) apparentPositions end methods function obj = landmarks(mapSize, numberOfTrees) obj.mapSize = mapSize; obj.fixedPositions = obj.mapSize * rand([numberOfTrees, 2]) .* sign(rand([numberOfTrees, 2]) - 0.5); end function apparent = get.apparentPositions(obj) %-STILL ROTATES AROUND ORIGINAL ORIGIN currentPosition = [obj.x ; obj.y]; apparent = bsxfun(@minus,(obj.fixedPositions)',currentPosition)'; apparent = ([cosd(obj.heading) -sind(obj.heading) ; sind(obj.heading) cosd(obj.heading)] * (apparent)')'; end end end ---------- classdef robot properties x y heading velocity headingChange end methods function obj = robot(x,y,heading,velocity) obj.x = x; obj.y = y; obj.heading = heading; obj.velocity = velocity; end end end ---------- function headingChange = navigate(n) %steeringChange = 5 * rand(1) * sign(rand(1) - 0.5); Most chaotic shit %Draw an S if n
所有时间均为北京时间。现在的时间是 13:20。
