旧 2019-12-04, 15:03   #1
默认 MATLABWindow应用程序无法启动。无法启动MATLABWindow应用程序
我在这里遵循教程,所有先前的步骤都有效,并且我使用的所有版本与git repo相同的确切版本,包括MATLAB 2018a。
>> cluster_sample MathWorks::System::IUserException [Error using matlab.internal.webwindow (line 310) MATLABWindow application failed to launch. Unable to launch the MATLABWindow application Error in matlab.ui.internal.controller.platformhost.CEFFigurePlatformHost/createView (line 58) this.CEF = matlab.internal.webwindow(peerModelInfo.URL, peerModelInfo.DebugPort, position); Error in matlab.ui.internal.controller.FigureController/createView (line 223) this.PlatformHost.createView(this.PeerModelInfo, pos, title, visible, resizable, windowState); Error in matlab.ui.internal.componentframework.WebComponentController/add (line 75) obj.createView( parentController, parentView, map ); Error in matlab.ui.internal.controller.WebCanvasContainerController/add (line 52) [email protected]tainerController( this, webComponent, parentController ); Error in matlab.ui.internal.componentframework.WebControllerFactory/create (line 93) component.createController( parentController, [] );] MathWorks::System::IUserException [Dot indexing is not supported for variables of this type. Error in matlab.ui.internal.componentframework.services.core.eventhandling.WebEventHandlingService/setProperty (line 199) obj.ProxyView.PeerNode.setProperties( javaMap ); Error in matlab.ui.internal.controller.WebCanvasContainerController/updateSceneChannel (line 137) obj.EventHandlingService.setProperty('SceneServer', propValue); Error in matlab.ui.internal.controller.WebCanvasContainerController/set.Canvas (line 91) updateSceneChannel(obj); Error in matlab.ui.internal.componentframework.WebControllerFactory/create (line 93) component.createController( parentController, [] );] >> 如果在https://github.com/talmo/leap/wiki/Tutorial:-Training-LEAP-from-scratch中搜索cluster_sample,则可以找到说明。输入此命令后,我应该会看到一个GUI。我怎样才能解决这个问题?
也,
>> pwd ans = '/scratch3/3d_pose/animalpose/leap' >> cd(matlabroot) >> pwd ans = '/ifs/common/IT/matlab-9.4' >> ! bin/glnxa64/MATLABWindow bin/glnxa64/MATLABWindow: symbol lookup error: /lib64/libpango-1.0.so.0: undefined symbol: g_log_structured_standard (base) [jalal@goku animalpose]$ lsb_release -a LSB Version: :core-4.1-amd64:core-4.1-noarch Distributor ID: CentOS Description: CentOS Linux release 7.7.1908 (Core) Release: 7.7.1908 Codename: Core (base) [jalal@goku animalpose]$ uname -a Linux goku.bu.edu 3.10.0-1062.4.3.el7.x86_64 #1 SMP Wed Nov 13 23:58:53 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
