旧 2019-11-27, 07:35   #1
声望力: 68
默认 Digital Output Using NI BNC-2110 connect to NI USB-6255
I currently have NI BNC-2110 connect to the NI USB-6255 which is then connected to my computer.
My goal is to generate a digital output through the NI BNC-2110 and then read the output on an analog input on the same NI BNC-2110. (The perpose of this is to make sure that I know how to properly output a digital signal and can input an analog signal, and I figured this would just check both things simultaneously.)
The setup works when generating a digital signal and reading an analog when I use the software NI MAX, my problem is when I try and do the same thing in matlab.
Here is my current code in matlab:
d = daq.getDevices
s = daq.createSession('ni');
addAnalogInputChannel(s,'dev1', 'ai0', 'Voltage');
s.Rate = 8000;
q = daq.createSession('ni');
addDigitalChannel(q,'dev1','Port2/Line0:0','OutputOnly');
for p = 1:1:100
outputSingleScan(q,1)
pause(0.1)
data = s.inputSingleScan;
data
outputSingleScan(q,0)
pause(0.1)
data
My current results are an analog input of ~0 Volts, and what I expect is a square wave from my analog input.
Any help on this would be much appreciated.
I am expecting somthing with a syntax in matlab with port to be the problem, but not to sure.
Thank you, Avery
More answer...
所有时间均为北京时间。现在的时间是 05:31。
