旧 2008-01-06, 16:32   #1
TechnicalArticles
游客
帖子: n/a
默认 Modeling Flexible Bodies in SimMechanics and Simulink
SimMechanics and Simulink combine to form an efficient tool for simulating rigid-body mechanical systems, especially in control systems applications. These products also enable you to simulate flexible body motion—a frequent requirement in aerospace, automotive, civil engineering, and other industries. Because the SimMechanics Body block represents only a rigid body, you must first transform your continuous flexible body into an approximate form that you can represent in Simulink. SimMechanics can then simulate flexibility with a fidelity that is sufficient for many applications, such as control design.
  回复时引用此帖
