#1 |
注册日期: 2007-04-05
声望力: 29 ![]() ![]() ![]() ![]() |
实例27:设置照明方式
function shili27 h0=figure('toolbar','none',... 'position',[200 150 450 350],... 'name','实例27'); subplot(2,2,1) sphere shading flat camlight left camlight right lighting flat colorbar axis off title('Figure1') subplot(2,2,2) sphere shading flat camlight left camlight right lighting gouraud colorbar axis off title('Figure2') subplot(2,2,3) sphere shading interp camlight right camlight left lighting phong colorbar axis off title('Figure3') subplot(2,2,4) sphere shading flat camlight left camlight right lighting none colorbar axis off title('Figure4') 实例28:羽状图 function shili28 h0=figure('toolbar','none',... 'position',[200 150 450 350],... 'name','实例28'); subplot(2,1,1) alpha=90:-10:0; r=ones(size(alpha)); m=alpha*pi/180; n=r*10; [u,v]=pol2cart(m,n); feather(u,v) title('羽状图') axis([0 20 0 10]) subplot(2,1,2) t=0:0.5:10; x=0.05+i; y=exp(-x*t); feather(y) title('复数矩阵的羽状图') 实例29:立体透视(1) function shili29 h0=figure('toolbar','none',... 'position',[200 150 450 250],... 'name','实例29'); [x,y,z]=meshgrid(-2:0.1:2,... -2:0.1:2,... -2:0.1:2); v=x.*exp(-x.^2-y.^2-z.^2); grid on for i=-2:0.5:2; h1=surf(linspace(-2,2,20),... linspace(-2,2,20),... zeros(20)+i); rotate(h1,[1 -1 1],30) dx=get(h1,'xdata'); dy=get(h1,'ydata'); dz=get(h1,'zdata'); delete(h1) slice(x,y,z,v,[-2 2],2,-2) hold on slice(x,y,z,v,dx,dy,dz) hold off axis tight view(-5,10) drawnow end 实例30:立体透视(2) function shili30 h0=figure('toolbar','none',... 'position',[200 150 450 250],... 'name','实例30'); [x,y,z]=meshgrid(-2:0.1:2,... -2:0.1:2,... -2:0.1:2); v=x.*exp(-x.^2-y.^2-z.^2); [dx,dy,dz]=cylinder; slice(x,y,z,v,[-2 2],2,-2) for i=-2:0.2:2 h=surface(dx+i,dy,dz); rotate(h,[1 0 0],90) xp=get(h,'xdata'); yp=get(h,'ydata'); zp=get(h,'zdata'); delete(h) hold on hs=slice(x,y,z,v,xp,yp,zp); axis tight xlim([-3 3]) view(-10,35) drawnow delete(hs) hold off end 实例31:表面图形 function shili31 h0=figure('toolbar','none',... 'position',[200 150 550 250],... 'name','实例31'); subplot(1,2,1) x=rand(100,1)*16-8; y=rand(100,1)*16-8; r=sqrt(x.^2+y.^2)+eps; z=sin(r)./r; xlin=linspace(min(x),max(x),33); ylin=linspace(min(y),max(y),33); [X,Y]=meshgrid(xlin,ylin); Z=griddata(x,y,z,X,Y,'cubic'); mesh(X,Y,Z) axis tight hold on plot3(x,y,z,'.','Markersize',20) subplot(1,2,2) k=5; n=2^k-1; theta=pi*(-n:2:n)/n; phi=(pi/2)*(-n:2:n)'/n; X=cos(phi)*cos(theta); Y=cos(phi)*sin(theta); Z=sin(phi)*ones(size(theta)); colormap([0 0 0;1 1 1]) C=hadamard(2^k); surf(X,Y,Z,C) axis square 实例32:沿曲线移动的小球 h0=figure('toolbar','none',... 'position',[198 56 408 468],... 'name','实例32'); h1=axes('parent',h0,... 'position',[0.15 0.45 0.7 0.5],... 'visible','on'); t=0:pi/24:4*pi; y=sin(t); plot(t,y,'b') n=length(t); h=line('color',[0 0.5 0.5],... 'linestyle','.',... 'markersize',25,... 'erasemode','xor'); k1=uicontrol('parent',h0,... 'style','pushbutton',... 'position',[80 100 50 30],... 'string','开始',... 'callback',[... 'i=1;',... 'k=1;,',... 'm=0;,',... 'while 1,',... 'if k==0,',... 'break,',... 'end,',... 'if k~=0,',... 'set(h,''xdata'',t(i),''ydata'',y(i)),',... 'drawnow;,',... 'i=i+1;,',... 'if i>n,',... 'm=m+1;,',... 'i=1;,',... 'end,',... 'end,',... 'end']); k2=uicontrol('parent',h0,... 'style','pushbutton',... 'position',[180 100 50 30],... 'string','停止',... 'callback',[... 'k=0;,',... 'set(e1,''string'',m),',... 'p=get(h,''xdata'');,',... 'q=get(h,''ydata'');,',... 'set(e2,''string'',p);,',... 'set(e3,''string'',q)']); k3=uicontrol('parent',h0,... 'style','pushbutton',... 'position',[280 100 50 30],... 'string','关闭',... 'callback','close'); e1=uicontrol('parent',h0,... 'style','edit',... 'position',[60 30 60 20]); t1=uicontrol('parent',h0,... 'style','text',... 'string','循环次数',... 'position',[60 50 60 20]); e2=uicontrol('parent',h0,... 'style','edit',... 'position',[180 30 50 20]); t2=uicontrol('parent',h0,... 'style','text',... 'string','终点的X坐标值',... 'position',[155 50 100 20]); e3=uicontrol('parent',h0,... 'style','edit',... 'position',[300 30 50 20]); t3=uicontrol('parent',h0,... 'style','text',... 'string','终点的Y坐标值',... 'position',[275 50 100 20]); 实例33:曲线转换按钮 h0=figure('toolbar','none',... 'position',[200 150 450 250],... 'name','实例33'); x=0:0.5:2*pi; y=sin(x); h=plot(x,y); grid on huidiao=[... 'if i==1,',... 'i=0;,',... 'y=cos(x);,',... 'delete(h),',... 'set(hm,''string'',''正弦函数''),',... 'h=plot(x,y);,',... 'grid on,',... 'else if i==0,',... 'i=1;,',... 'y=sin(x);,',... 'set(hm,''string'',''余弦函数''),',... 'delete(h),',... 'h=plot(x,y);,',... 'grid on,',... 'end,',... 'end']; hm=uicontrol(gcf,'style','pushbutton',... 'string','余弦函数',... 'callback',huidiao); i=1; set(hm,'position',[250 20 60 20]); set(gca,'position',[0.2 0.2 0.6 0.6]) title('按钮的使用') hold on 实例34:栅格控制按钮 h0=figure('toolbar','none',... 'position',[200 150 450 250],... 'name','实例34'); x=0:0.5:2*pi; y=sin(x); plot(x,y) huidiao1=[... 'set(h_toggle2,''value'',0),',... 'grid on,',... ]; huidiao2=[... 'set(h_toggle1,''value'',0),',... 'grid off,',... ]; h_toggle1=uicontrol(gcf,'style','togglebutton',... 'string','grid on',... 'value',0,... 'position',[20 45 50 20],... 'callback',huidiao1); h_toggle2=uicontrol(gcf,'style','togglebutton',... 'string','grid off',... 'value',0,... 'position',[20 20 50 20],... 'callback',huidiao2); set(gca,'position',[0.2 0.2 0.6 0.6]) title('开关按钮的使用') 实例35:编辑框的使用 h0=figure('toolbar','none',... 'position',[200 150 350 250],... 'name','实例35'); f='Please input the letter'; huidiao1=[... 'g=upper(f);,',... 'set(h2_edit,''string'',g),',... ]; huidiao2=[... 'g=lower(f);,',... 'set(h2_edit,''string'',g),',... ]; h1_edit=uicontrol(gcf,'style','edit',... 'position',[100 200 100 50],... 'HorizontalAlignment','left',... 'string','Please input the letter',... 'callback','f=get(h1_edit,''string'');',... 'background','w',... 'max',5,... 'min',1); h2_edit=uicontrol(gcf,'style','edit',... 'HorizontalAlignment','left',... 'position',[100 100 100 50],... 'background','w',... 'max',5,... 'min',1); h1_button=uicontrol(gcf,'style','pushbutton',... 'string','小写变大写',... 'position',[100 45 100 20],... 'callback',huidiao1); h2_button=uicontrol(gcf,'style','pushbutton',... 'string','大写变小写',... 'position',[100 20 100 20],... 'callback',huidiao2); 实例36:弹出式菜单 h0=figure('toolbar','none',... 'position',[200 150 450 250],... 'name','实例36'); x=0:0.5:2*pi; y=sin(x); h=plot(x,y); grid on hm=uicontrol(gcf,'style','popupmenu',... 'string',... 'sin(x)|cos(x)|sin(x)+cos(x)|exp(-sin(x))',... 'position',[250 20 50 20]); set(hm,'value',1) huidiao=[... 'v=get(hm,''value'');,',... 'switch v,',... 'case 1,',... 'delete(h),',... 'y=sin(x);,',... 'h=plot(x,y);,',... 'grid on,',... 'case 2,',... 'delete(h),',... 'y=cos(x);,',... 'h=plot(x,y);,',... 'grid on,',... 'case 3,',... 'delete(h),',... 'y=sin(x)+cos(x);,',... 'h=plot(x,y);,',... 'grid on,',... 'case 4,',... 'delete(h),',... 'y=exp(-sin(x));,',... 'h=plot(x,y);,',... 'grid on,',... 'end']; set(hm,'callback',huidiao) set(gca,'position',[0.2 0.2 0.6 0.6]) title('弹出式菜单的使用') hold on |
#2 |
注册日期: 2007-06-21
声望力: 0 ![]() |
hao 3x!!!!!!!!!
#3 |
注册日期: 2007-11-29
声望力: 0 ![]() |
爽,楼主好牛啊谢谢了啊
