旧 2019-12-10, 20:42   #1
帖子 根据条件,图形背景的颜色指定区域
我有一个条形图(2D),我想将背景的红色设为另一个向量的值大于1的部分,即
例:
图表= [2 3 5 4 9 1 7]颜色= [0 2 2 1 0 1 2]
因此该条形图将显示通常的条形,并且其后面的背景(包括条形之间的空间)在“ 3”,“ 5”和“ 7”的条形后面(位置2、3、7)被涂成红色。
蓝色示例:
有可能吗?
谢谢
是的,这是可能的
%# define some parameters backgroundColor = 'r'; backgroundWidth = 0.9; foregroundWidth = 0.3; %# collect the data graph = [2 3 5 4 9 1 7]; color = [0 2 2 1 0 1 2]; x = 0:length(graph)-1; colIdx = color>1; bgBarHeight = max(graph)+1; %# background bars are 1 taller than max %# first, plot red bars - I plot them as background as in your question, %# not as transparent overlay as in your example (see yuk's answer for that) bar(x,colIdx*bgBarHeight,backgroundWidth,'FaceColor',backgroundColor,'EdgeColor','none') %# use hold on to prevent background from disappearing hold on %# then, plot foreground bars. Use hold on so that the background isn't lost bar(x,graph,foregroundWidth,'FaceColor','k') %# label the axes xlabel('X Axis') ylabel('Y Axis')
所有时间均为北京时间。现在的时间是 02:16。
