旧 2019-11-25, 14:23   #1
默认 Using Euler's method to graph in matlab
having some trouble with this code. My professor asked us to create a function "feuler.m" in matlab to solve the initial-value problem given by the differential equation u′(t) = (2+2t)e^t and the initial condition u(0) = 0 over the interval [0, 5] that uses (forward) Euler’s method to graph the exact solution along with the approximate solution.
The input should be: n, the number of subintervals into which the interval [0,5] should be divided.
The output should be a graph of the exact solution and the numerical solution and print the value of the maximum error between the true solution and the numerical solution.
Note that the exact solution is given by u(t) = 2tet.
So far I have written the code:
function myeuler(N)
t = linspace(0, 5, N+1)';
ua = zeros(N+1,1);
ue = 2*t.*exp(t);
h = 5/N;
A = zeros(N,N);
A(2:N,1:N-1) = -eye(N-1);
A= A + eye(N);
b = h*(2+2*t(1:N)).*exp(t(1:N));
b(1) = b(1) + ua(1);
ua(2:N+1) = A\b;
plot(t, ua, 'r', t, ue, 'g')
Unsure if this is right.
Thanks for any help!
More answer...
所有时间均为北京时间。现在的时间是 01:22。
