旧 2009-05-05, 17:26   #1
小文
注册日期: 2009-03-24
小文 正向着好的方向发展
默认 关于心电信号奇异点与其小波变换模极大值对的零交叉点的关系?请教下面程序应该如何理解哈
%**************************************求正负极大值对*****************************************%
ddw=zeros(size(swd))
pddw=ddw;
nddw=ddw;
%小波系数的大于0的点
posw=swd.*(swd>0);
%斜率大于0
pdw=((posw(,1 points-1)-posw( ,2 points))<0);
%正极大值点
pddw( ,2points-1)=((pdw( ,1points-2)-pdw(,2points-1))>0);
%小波系数小于0的点
negw=swd.*(swd<0);
ndw=((negw(,1points-1)-negw(,2points))>0);
%负极大值点
nddw(,2points-1)=((ndw(,1oints-2)-ndw(,2points-1))>0);
%或运算
ddw=pddw|nddw;
ddw(,1)=1;
ddw(,points)=1;
%求出极值点的值,其他点置0
wpeak=ddw.*swd;
wpeak(,1)=wpeak(,1)+1e-10;
wpeak(,points)=wpeak(,points)+1e-10;
%画出各尺度下极值点
figure;
for i=1:level
subplot(level,1,i);
plot(wpeak(i,)) axis tight;grid on;
ylabel(strcat('j= ',num2str(i)))
subplot(4,1,1);
title('ECG信号在j=1,2,3,4尺度下的小波系数的模极大值点');
interva2=zeros(1,points);
intervaqs=zeros(1,points);
Mj1=wpeak(1,);
Mj4=wpeak(3,);
%画出尺度3极值点
figure;
plot (Mj4);
title('尺度3下小波系数的模极大值点');
posi=Mj4.*(Mj4>0);
%求正极大值的平均
thposi=(max(posi(1:round(points/4)))+max(posi(round(points/4):2*round(points/4)))+max(posi(2*round(points/4):3*round(points/4)))+max(posi(3*round(points/4):4*round(points/4))))/4;
posi=(posi>thposi/3);
nega=Mj4.*(Mj4<0);
%求负极大值的平均
thnega=(min(nega(1:round(points/4)))+min(nega(round(points/4):2*round(points/4)))+min(nega(2*round(points/4):3*round(points/4)))+min(nega(3*round(points/4):4*round(points/4))))/4;
nega=-1*(nega<thnega/4);
%找出非0点
interva=posi+nega;
loca=find(interva);
for i=1:length(loca)-1
if abs(loca(i)-loca(i+1))<80
diff(i)=interva(loca(i))-interva(loca(i+1));
diff(i)=0;
%找出极值对
loca2=find(diff==-2);
%负极大值点
interva2(loca(loca2(1:length(loca2))))=interva(loca(loca2(1 length(loca2))));
%正极大值点
interva2(loca(loca2(1:length(loca2))+1))=interva(loca(loca2(1 length(loca2))+1));
intervaqs(1oints-10)=interva2(11 points);
count=zeros(1,1);
count2=zeros(1,1);
count3=zeros(1,1);
mark1=0;
mark2=0;
mark3=0;
i=1;
j=1;
Rnum=0;
%*************************求正负极值对过零,即R波峰值,并检测出QRS波起点及终点*******************%
while i<points
if interva2(i)==-1
mark1=i;
i=i+1;
while(i<points&interva2(i)==0)
i=i+1;
mark2=i;
%求极大值对的过零点
mark3= round((abs(Mj4(mark2))*mark1+mark2*abs(Mj4(mark1)))/(abs(Mj4(mark2))+abs(Mj4(mark1))));
%R波极大值点
R_result(j)=mark3-10;
count(mark3-10)=1;
%求出QRS波起点
kqs=mark3-10;
markq=0;
while (kqs>1)&&( markq< 3)
if Mj1(kqs)~=0
markq=markq+1;
kqs= kqs -1;
count2(kqs)=-1;
%求出QRS波终点
kqs=mark3-10;
marks=0;
while (kqs<points)&&( marks<2)
if Mj1(kqs)~=0
marks=marks+1;
kqs= kqs+1;
count3(kqs)=-1;
i=i+60;
j=j+1;
Rnum=Rnum+1;
i=i+1;
%************************删除多检点,补偿漏检点**************************%
num2=1;
while(num2~=0)
num2=0;
%j=3,过零点
R=find(count);
%过零点间隔
R_R=R(2:length(R))-R(1:length(R)-1);
RRmean=mean(R_R);
%当两个R波间隔小于0.4RRmean时,去掉值小的R波
for i=2:length(R)
if (R(i)-R(i-1))<=0.4*RRmean
num2=num2+1;
if signal(R(i))>signal(R(i-1))
count(R(i-1))=0;
count(R(i))=0;
num1=2;
while(num1>0)
num1=num1-1;
R=find(count);
RRmean=mean(R_R);
%当发现R波间隔大于1.6RRmean时,减小阈值,在这一段检测R波
for i=2:length(R)
if (R(i)-R(i-1))>1.6*RRmean
Mjadjust=wpeak(4,R(i-1)+80:R(i)-80);
points2=(R(i)-80)-(R(i-1)+80)+1;
%求正极大值点
adjustposi=Mjadjust.*(Mjadjust>0);
adjustposi=(adjustposi>thposi/4);
%求负极大值点
adjustnega=Mjadjust.*(Mjadjust<0);
adjustnega=-1*(adjustnega<thnega/5);
%或运算
interva4=adjustposi+adjustnega;
%找出非0点
loca3=find(interva4);
diff2=interva4(loca3(1:length(loca3)-1))-interva4(loca3(2:length(loca3)));
%如果有极大值对,找出极大值对
loca4=find(diff2==-2);
interva3=zeros(points2,1)';
for j=1:length(loca4)
interva3(loca3(loca4(j)))=interva4(loca3(loca4(j)));
interva3(loca3(loca4(j)+1))=interva4(loca3(loca4(j)+1));
mark4=0;
mark5=0;
mark6=0;
while j<points2
if interva3(j)==-1;
mark4=j;
j=j+1;
while(j<points2&interva3(j)==0)
j=j+1;
mark5=j;
%求过零点
mark6= round((abs(Mjadjust(mark5))*mark4+mark5*abs(Mjadjust(mark4)))/(abs(Mjadjust(mark5))+abs(Mjadjust(mark4))));
count(R(i-1)+80+mark6-10)=1;
j=j+60;
j=j+1;
%画出原图及标出检测结果
figure;
plot(ecgdata(0*4096+1:1*4096)),grid on,axis tight,axis([1,points,-2,5]);
title('ECG信号的R波峰值及QRS波波段');
hold on
plot(count,'r');
plot(count2,'k');
plot(count3,'k');
for i=1:Rnum
if R_result(i)==0;
break
plot(R_result(i),ecgdata(R_result(i)),'bo','MarkerSize',10,'MarkerEdgeColor','g');
hold off
小文 当前离线   回复时引用此帖
旧 2009-05-05, 19:30   #2
小文
注册日期: 2009-03-24
小文 正向着好的方向发展
默认 回复: 关于心电信号奇异点与其小波变换模极大值对的零交叉点的关系?请教下面程序应该如何理解哈
版主能不能帮忙大概解释下该程序哦?谢过了
小文 当前离线   回复时引用此帖
旧 2010-03-30, 09:38   #3
ghostman1113
注册日期: 2010-03-30
ghostman1113 正向着好的方向发展
你的程序有点问题,是求模极大值对的方法
ghostman1113 当前离线   回复时引用此帖
所有时间均为北京时间。现在的时间是 01:14。
